My trigger keeps cutting out
My vacum will run for a few seconds when I first pull the trigger and then it starts cutting out
Esta é uma boa pergunta?
If your Dyson v6 Absolute vacuum cleaner unexpectedly turns off during use, see the Dyson v6 Absolute Shuts Off While In Use problem page for possible causes and solutions.
If your Dyson v6 Absolute vacuum cleaner’s battery life is not long enough to complete a vacuuming task, see the Dyson v6 Absolute Battery Life Is Too Short problem page for possible causes and solutions.
Probably a worn-out tab on your filter not tripping the switch.
Here’s a video on how to fix it:
Esta resposta foi útil?
Is there any blockages?
Dirty filter? This is notorious for stopping my V7.
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 32
Ao todo: 10,228
1 comentário
Why isn't my Dyson charging?
Or you may have some intermittent component problem. Having a good power source is best for troubleshooting other potential problems so checking the battery status is a good first step.
por prop man
