Ir para o conteúdo principal
Guias de reparo, desmontagem e informações de resolução de problemas para a terceira geração do iPad da Apple com 4G, disponível com 16, 32 ou 64 GB de armazenamento. Lançado em março de 2012. Identificado pelos números de modelo A1430 (GSM, AT&T) ou A1403 (CDMA, Verizon). Os reparos exigem o uso de calor e alavancagem cuidadosa.
Home screen display problem
I just replaced the cracked screen on my ipad3. It turned on okay but the home screen is not displaying correctly. There is a thick black line down the middle of the screen. One half of the screen is displaying fine and the other half is distorted. Icons seem to be all working. I’ve check my connections a few times and all seem to be inserted correctly. I can figure out what is wrong.
Update (06/30/2019)
Attached is an image of the screen. If it is a damaged connector is that an easy fix? Thank you all for your help.
Imagem
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Can you take a close look at the LCD connectors on both the ribbon cable and logic board? They may have gotten damaged when being reconnected.
por Compartilhar
Adicionar um comentário
1 resposta
Solução escolhida
The LCD is really easy to damage and I suspect that this is the case here. Can you post a picture of the screen (add it to your question)? That would allow us to see the “damage” and offer a better diagnostic. As da stunner suggests, it could be a damaged LCD flex but in my experience, they are quite thick and rarely get torn.
The other thing to look at is the LCD connector on the logic board. It has the little flap that must be raised to remove/insert the flex. If that gets damaged, then the flex is not properly tensioned to ensure good contact.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Laura o será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 13
Ao todo: 343
