Ir para o conteúdo principal
Lançado em 22 de setembro de 2017. Modelo A1864, A1897. Disponível como GSM ou CDMA / 64 ou 256 GB / Cores Ouro, Prata e Cinza Espacial.
678 Perguntas Visualizar todos
Logic board heat shield ripped a little what do I do?
Hello I was trying to unscrew a screw near the logic board and my screw driver slipped and made a little rip and made a scratch under it can i just put heat resistant tape over it or do i just leave it thanks!
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Please add a photo of what you mean
por
Ok i posted the photos
por
Adicionar um comentário
2 respostas
Solução escolhida
Honestly I would even worry about it. Just try not to do it again. I’ve seen boards with all of that’s stuff gone and they’re fine. Getting a new logic board is not necessary.
Esta resposta foi útil?
Pontuação 1
You need to get a new logic board. That’s not safe for you or the phone, the thermal paste that was there is now exposed and the processor can no longer connecting to any cooling device. The device is going to overheat and break itself or worse.
Pontuação 0
2 comentários:
It wasnt Near the cpu so maybe not?
por
Based on the pictures the OP provided, none of what you fear is actually true. It's just the black sheathing that is slightly torn.
por
Adicionar a sua resposta
Voyger ` será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 462
