Ir para o conteúdo principal
O smartwatch de terceira geração da Apple, com conectividade celular opcional, lançado em 22 de setembro de 2017.
Not charging correctly. Plz help
My Apple Watch series 3 got water damage a couple of days ago. I soaked in alcohol for a day and then let dry. When I plugged on charger, it showed the green charging sign. I unplugged it and replugged it and now nothing happens, except after 30 mins a screen covered in different color led shows up. When I unplug it dies instantly. Plz help
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
3 respostas
Pergunta mais útil
I think you need a new battery.
Esta resposta foi útil?
Pontuação 1
1 comentário:
My watch also screen cracked & water damaged
I kept near the fan for whole day
Next day after puts on charger it booted up
But not charging it was stuck on 1% not increasing
Immediately I checked battery health on watch it’s showing service recommended
Previously it was 100%
I tried with 2 hours I put charger but no use
While plug it off after couple of minutes it’s been turned off
In my case replacing battery is solution or any other solution have to do
por
I got this my d00d.
What might be the problem (this happens to me sometimes) is that your putting the Apple Watch on the charger and it would seem to be charging, but it isn’t. The charger has two sides, and one of them is magnetic, and the other one does nothing. You have to make sure it magnetically sticks onto the charger, and then something will appear on the screen saying it is charging. If that isn’t working, the charger may be broken.
Hope this helped my d00d.
Pontuação 0
1 comentário:
Thank you. But It sticks on, and the charger is broken cause it works on the other watch. If u can provide further info if be thankful.
por
It seems to me from your description that the watch was never disassembled and you just placed the whole watch in alcohol. I recommend a full disassembly to inspect and clean. Teardown do Apple Watch Series 3
Electronics Water Damage
https://www.youtube.com/watch?v=DsDpALKQ...
Pontuação 0
Adicionar a sua resposta
Ibrahim Asfari será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Ao todo: 742
