Ir para o conteúdo principal
The display does not turn on after replacing the battery.
After one screen break, I watched YouTube at home (I did not know ifix at that time). After a few months after the repair was successful, I felt that the battery could not function properly and replaced it. However, after replacing the battery, I covered the liquid crystal again and a black line appeared, so I assembled again and I heard only the sound and the screen did not turn on. I want to solve this phenomenon, but it seems to be selling the part in ifix. What part would solve my problem? I have about 10 repair experience, but I do not even know what parts I need to buy in case of a breakdown. I also apologize in advance for the lack of English language skills and the lack of sophistication in terms of word order and vocabulary
Esta é uma boa pergunta?
Pontuação 0
3 comentários
Did you replace the screen with the battery connected
por
아니요 유투브를 보고 그대로 따라한것이라 모든 수리과정에서 베터리는 제일 먼저 빼고 제일 나중에 꼽았습니다만 4번의 수리중 두번은 베터리를 중간에 뽑은적이 있는거같습니다
por
No, I watched Youtube and followed it up. During the whole repair process, except for the first one, I picked it the last time.
por
Adicionar um comentário
3 respostas
Solução escolhida
If you take the iPhone apart again ,and try taking out the battery for a few minutes. After a few minutes is over put the battery back in if it continues to not work try replacing your LCD, digitizer and or the whole display.
如果再次拆开iPhone,请尝试取出电池几分钟。几分钟结束后,如果电池继续不工作,请将电池放回原位,尝试更换LCD,数字转换器和/或整个显示器。
Si vuelve a desmontar el iPhone, intente quitar la batería durante unos minutos. Después de unos minutos, si la batería sigue sin funcionar, vuelva a colocarla en su lugar e intente reemplazar la pantalla LCD, el digitalizador y / o toda la pantalla.
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
So it seems like you should replace you’r screen. Before you do that make sure that the connector from the battery is properly connected.
Pontuação 1
4 comentários:
답변 감사합니다 하지만 그렇게 된 이후 잘못된 것을 깨닫고 다시 부품을 사서 조립을 해 봣지만 여전히 작동하지 않앗습니다 다른 보드혹은 모듈 전선의 문제라고 생각이 드는데 어느 부품을 사면 되는지 아시면 알려주실 수 있으신가요?
por
I'm sorry sir i cant read what you rote i speak English only.
por
Thank you for your answer, but after that, I realized something was wrong and I bought the parts and put them together again, but they still didn't work. I think it's another board or a module wire problem. Can you tell me which parts I should buy?
por
Why dont you replace the screen?
por
It’s very important to always disconnect the battery before disconnecting/reconnecting the screen assembly. The issue is that the LCD connector has pins that have high voltages (i.e. the backlight is ~20V) and ground in very close proximity. When you fumble around trying to line up the connector plug to the receptacle, you can short out the voltage rail and cause damage to the components in the backlight circuit. If you’re lucky, then only a backlight filter is damaged but other times, the entire circuit could be affected. Either way, this type of repair requires micro-soldering and isn’t really a DIY repair.
To test for this, plug your device into a charger or an iTunes enabled computer. Then shine a bright flashlight on the screen. If you can see a dim image, then the backlight circuit has been damaged. If you can’t see an image at all, then it may be the LCD circuit that is damaged.
You can connect the original, cracked screen to confirm this. If the original screen has the backlight on, then the replacement screen has an issue. If the original screen also doesn't show the backlight, then the backlight circuit is blown.
If iTunes doesn’t recognized the device than the problem is more than just a screen or backlight issue.
Pontuação 1
Adicionar a sua resposta
김태현 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 88
