Ir para o conteúdo principal
O SanDisk Cruzer Glide é um pen drive com conector USB retrátil. Ele é comercializado em várias capacidades de armazenamento, com um corpo de plástico preto e vermelho em todos os modelos.
Is this Flash Drive fixable?
I accidentally droped the laptop that this was plugged in to… the cover for it split and when we went to plug it back in, it wasn’t showing up on the computer. I feel like this can be fixed easily since the connection to the motherboard is still intact… It’s just not showing up on the laptop.
Imagem
Imagem
Imagem
Imagem
Esta é uma boa pergunta?
Pontuação 0
1 comentário
It probably cant be fixed unless you go to a professional so unless you have information you need on it then give up. Or if your lucky you can play around with it and it will work. Good luck
por Compartilhar
Adicionar um comentário
1 resposta
Solução escolhida
I agree that it probably can be fixed but easily…no. It’s hard to say from the pictures but when a USB drive is physically damaged, it usually means some traces on the circuit board are damaged. This can be fixed but it requires micro-soldering and that makes any DIY repair unlikely.
Here’s an example of the type of damage I am referring to.
Imagem
If you value the data on the drive, you could send your USB Drive to a micro-soldering repair specialist.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Brett W será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 18
Ao todo: 973
