Ir para o conteúdo principal
Lançado em junho de 2012 / processador Core i7 com Turbo Boost / até 1 GB de VRAM GDDR5
Replacement battery keeps not being recognized
I ordered and installed a replacement battery from iFixit and it seemed to be working fine for a while, however after running for a while the battery will not be recognized. When this happens, if I shut down and reset the SMC it will work again for a while but will later do the same thing resulting in needing another SMC reset.
I’ve also reset the PRAM along with updating to the latest SMC firmware for my Mac model all to no avail. I’ve inspected the battery connections many times and it appears to be plugged in just fine. I figured it’s not due to a faulty connection since a SMC reset kicks it back into gear, but this issue is really messing with my workflow.
Any help is greatly appreciated!
EDIT: I’ve also downloaded and ran CoconutBattery. After a fresh SMC reset, coconut says that the battery is in good condition and has no issues.
EDIT 2: Here is a screenshot of CoconutBattery with the SMC freshly reset (battery working)
Imagem
Here is after battery stops being recognized:
Imagem
Esta é uma boa pergunta?
Pontuação 3
1 comentário
install this gem of an app CoconutBattery paste a snapshot of the main window for here so we can see whats happening Adicionar imagens a uma pergunta já existente
por
Adicionar um comentário
5 respostas
Pergunta mais útil
Did you contact them? I promise you they will replace it!
Contact iFixit Customer Support
Esta resposta foi útil?
Pontuação 1
For what it’s worth, I’m having the exact issue, and I’m on my second iFixit battery. The first one had this issue, so I tried unplugging and replugging in the battery connector and resetting SMC and PRAM all multiple times to no avail. I contacted customer service, and they were kind enough to send out another battery, but unfortunately, this one is having the same issue even with the troubleshooting described above. I can’t imagine a third will behave any differently. My Apple battery does not have the same issue, so I believe the problem has to be confined to these replacement batteries.
Pontuação 1
2 comentários:
They kindly sent me a new battery too.
But if you say true and none battery of this model works, I hope there will be a solution of refund.
por
My second new battery works perfectly, thank you all and thank you iFixit!
por
Hey,
I have exactly the same problem as explained above.
Here are my screenshots of coconutBattery (before and after the battery is no longer recognized), do you think I should also contact the support?
Imagem
https://i.imgur.com/8ic3V00.png
Imagem
https://i.imgur.com/I2nscLd.png
Note: I have the same serial number as cknazze battery has ''too?!?
Pontuação 0
2 comentários:
Contact IFIXIT store for a replacement as your battery is defective. The packing slip will have the info on how.
por
Great !
I'm going to do it, I just wanted to know if the second new cknazze battery worked well?
por
Hey there ill do have exect the same problem. Will contact the Support for replacement.
Pontuação 0
I’m having the same issue. Serial no is the same as cknazze. This is a coconut battery screenshot of when the MBP recognizes the battery. Can you see any obvious problems?
Imagem
I’ll post another screenshot from coconut when it stops recognizing the battery again.
Pontuação 0
1 comentário:
Hi There,
Augie from iFixit here! Although I'm sorry to learn of the issue, we'll be more than happy to help.
Was this ordered from iFixit? If so, could you please email us at support@ifixit.com with your order number (or email address used to place the order)?
From there, we'd be more than happy to help get this handled in no time.
Thanks again,
Augie
por
Adicionar a sua resposta
cknazze será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 18
Ao todo: 903
