Ir para o conteúdo principal
Xbox One controller was introduced in 2016 with the launch of the Xbox One S and adds Bluetooth support for Windows 10/11. This controller fixes many of the design flaws found on the Model 1537/1697 controllers and is much more reliable. This controller has been replaced with the improved Model 1914 controller.
Are Xbox One and Xbox One S controller faceplates interchangable
Is it possible to put an Xbox One controller faceplate on an Xbox One S controller (given that I have a complete original controller)
I want to have a Bluetooth model with a look of the Limited Edition Halo 5 controller…
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
Depends on how much you care about the warranty and if both controllers use the same faceplate and cosmetic parts. If it will work and you care about keeping the warranty, use a skin. If you don’t care (or it’s the 90 day warranty that isn’t worth preserving if you can do the work yourself), then it can be done.
You will need to damage the identifying label (which will reduce the resale of the controller) and make it harder to sell later on to normal buyers (technically capable buyers probably won’t care) so you need to decide if the resale loss and voided warranty are worth having that faceplate.
Esta resposta foi útil?
Pontuação 2
!Yes it would work and you only need to unbolt some screws and change the face plate Follow the guide!
Xbox One Wireless Controller Model 1708 Cover Plate Replacement
Pontuação 0
Adicionar a sua resposta
Vincent será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 22
Ao todo: 1,550
