Ir para o conteúdo principal
Xbox One Wireless Controller Model 1708 Cover Plate Replacement
O que você precisa
  1. Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Cover Plate: passo 1, imagem 1 %32 Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Cover Plate: passo 1, imagem 2 %32
    • Slide the battery cover toward the top of the controller to remove it.
    • Lift up the batteries or the battery pack from the battery compartment.
    Pergunte ao FixBot
    Comentar
  2. Xbox One Wireless Controller Model 1708 Cover Plate Replacement: passo 2, imagem 1 %32 Xbox One Wireless Controller Model 1708 Cover Plate Replacement: passo 2, imagem 2 %32
    • Insert a plastic opening tool into the top seam, and gently work the opening tool to the bottom of the controller.
    • Continue using the opening tool to gently pry the side plate off of the controller.
    • Repeat this process for the second side plate.
    Pergunte ao FixBot
    Comentar
  3. Xbox One Wireless Controller Model 1708 Cover Plate Replacement: passo 3, imagem 1 %32
    • Gently peel the battery label or punch a hole in the center of the sticker in the battery compartment to reveal the hidden screw.
    • Remove the five 9mm torx-9 security screws from the back of the controller.
    Pergunte ao FixBot
    Comentar
  4. Xbox One Wireless Controller Model 1708 Cover Plate Replacement: passo 4, imagem 1 %32 Xbox One Wireless Controller Model 1708 Cover Plate Replacement: passo 4, imagem 2 %32
    • Orient the controller so the front plate is facing up.
    • Lift the front cover off of the controller.
    Pergunte ao FixBot
    Comentar
  5. Xbox One Wireless Controller Model 1708 Cover Plate Replacement: passo 5, imagem 1 %32
    • Turn the controller face down and gently lift the rear plate.
    • Be careful with the rumble motors, as they tend to fall out, risking damage to the motherboard.
    Pergunte ao FixBot
    Comentar
  6. Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Tape Shock Motors in place: passo 6, imagem 1 %32 Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Tape Shock Motors in place: passo 6, imagem 2 %32 Xbox One Wireless Controller Model 1708 Cover Plate Replacement, Tape Shock Motors in place: passo 6, imagem 3 %32
    • Tape the Rumbler/shock motors in place.
    • This will prevent the motors from falling out.
    Pergunte ao FixBot
    Comentar
Conclusão
62 outras pessoas executaram este guia.
Equipe
Cal Poly, Team S18-G3, Forte Fall 2017 Membro de Cal Poly, Team S18-G3, Forte Fall 2017
CPSU-FORTE-F17S18G3
4 Membros
Autoria de 42 guias
5Comentários do guia
i used a t8 and it worked
Rudy Bp - Responder Compartilhar
T9 is VERY snug. T8 would probably be better but I don’t have one to try.
Craig Ferguson - Responder Compartilhar
T9 barely fits, I couldn’t even get 2 of the screws to turn. I think T8 works better
Baron Kube - Responder Compartilhar
One frustrating thing. All the guides I find on iFixit never give tips on reassembly. I'm having a difficult time getting the back plate back on. No help here, unfortunately.
Jim Pennington - Responder Compartilhar
how to remove from ass
Mr Rump - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 19
Últimos 7 dias: 113
Últimos 30 dias: 558
Ao todo: 37,712
