Ir para o conteúdo principal
Lançado em 22 de setembro de 2017. Modelo A1864, A1897. Disponível como GSM ou CDMA / 64 ou 256 GB / Cores Ouro, Prata e Cinza Espacial.
Home Button Flex snapped
Hi,
I was replacing the screen on my iPhone 8Plus and the flex for the home button snapped. The flex in question is the one that runs along the metal shield, not from the home button itself. Is this replaceable and if so, where can I get one from?
Cheers
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Solução escolhida
If the flex in question is the one that runs underneath the heat shield and connects to the logic board (see Step 44 of this Guide), then the only way to replace it is to replace the entire screen assembly. The little nub that connects to the Home Button Flex goes underneath the backlight and connects with the rest of the flex assembly which connects to the board. That flex cannot be replaced.
Esta resposta foi útil?
Pontuação 4
1 comentário:
I was fearful this was the case. I couldn't find any information on the internet that pointed to this but I guess I'll fork out for another screen. That will teach me for being so clumsy. Thank you!
por
I connected mine together using some solder and tape, it works.
Pontuação 0
Adicionar a sua resposta
Joel Innard será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 10
Ao todo: 402
