Ir para o conteúdo principal
Informações de reparo para o Asus Transformer Book T100TA. Lançado em aproximadamente 2013. Número do modelo: T100TA .
Slow when playing gaames
My laptop is really slow when gaming and I dont know what to do about it, I have tried a lot of things but nothing works,…
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
It depends on the game. Many entry level to midrange IGP only laptops handle games like The Sims okay since it’s not demanding, but will struggle to run more demanding games that recommend or require a dGPU. In many cases, professional graphics like the Radeon Pro and Quadro series will work but may struggle since these are optimized for certain workloads and are ISV certified.
Check the specs of the game and check out what it recommends for specs. If it’s within the specs of the game, then you may be running applications in the background that kill your available memory that should be closed. Likewise if your laptop isn’t very capable you will need a higher end laptop to run it correctly.
Esta resposta foi útil?
Pontuação 2
Well, the problem is that this is an older laptop meant to be a budget laptop for work/school/light to moderate personal use. It’s simply not meant to be the worlds best gaming laptop. If you do want a gaming laptop, try and sell this one first so you have some money and do your research on which gaming laptop you want.
Pontuação 1
2 comentários:
Its onl;y 4 years old...
por
@magicjet_ Still, this computer was never meant to be a gaming computer. You are better off selling this computer and getting a gaming computer if you wish to game on your computer.
por
Adicionar a sua resposta
Jen será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 17
Ao todo: 434
