Ir para o conteúdo principal
Controle PS4 modelo CUH-ZCT1. Lançado em novembro de 2013 pela Sony Computer Entertainment, este controlador de seis eixos com bateria de íon de lítio de 3,7 V é simples de reparar. (NOTA: O guia de desmontagem NÃO é para este modelo)
Why does my controller not charge?
My controller will not charge. Sometimes if you get it just right it will charge for about 4 seconds and then turn back off. What should I do?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
It may just be a battery issue. You can replace the battery with the part below. I also provided a guide on how to replace the battery.
DualShock 4 (CUH-ZCT1U) Battery Replacement
DualShock 4 (JDM-030 and Earlier) Controller Battery
Update (11/01/2018)
Here’s how you can replace your charge port, if necescery. Choose the right charge port for your model controller
DualShock 4 Charging Port Replacement
DualShock 4 Controller Charging Assembly (JDS-011)
DualShock 4 Controller Charging Assembly (JDS-001)
Imagem de MicroUSB charging port assembly for the 2nd generation (JDS-011) PS4 DualShock 4 controller
Produto
$8.99
Imagem de MicroUSB charging port assembly for the 1st generation (JDS-001) PS4 DualShock 4 controller
Produto
$5.99
Imagem de Replace a battery compatible with a PlayStation 4 DualShock 4 controller models JDM-001, JDM-011, JDM-020, or JDM-030.
Produto
$14.99
Imagem de DualShock 4 Battery
Guia
Nível de dificuldade:
Moderado
15 - 30 minutes
Imagem de DualShock 4 CHU-ZCT2U Charging Port
Guia
Moderado
25 - 40 minutes
Esta resposta foi útil?
Pontuação 2
2 comentários:
Hi @ajcooke01 ,
Not disagreeing with you but the OP states "Sometimes if you get it just right it will charge for about 4 seconds". I'm wondering if the "....get it just right..." relates to the USB cable connection and perhaps it may be a loose or damaged port.
Your thoughts? ;-)
por
I haven't had time to get around to fixing it but I am going to this weekend. That could be a possibility as well. If you have a link to a guide that might help me with that it would be much appreciated!
por
Adicionar a sua resposta
Wes Knutson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 8
Ao todo: 167
