Ir para o conteúdo principal
Lançado em 22 de setembro de 2017. Modelo A1863, A1905. Disponível com GSM ou CDMA / 64 ou 256 GB / Dourado, Prateado e Cinza Espacial.
873 Perguntas Visualizar todos
Help identify iPhone 8 logic board components
I have an iPhone 8 that will not come on I’ve identified one of the components close to the battery port connector (RV3C002UN) but am having trouble identifying another component to its immediate left. A mirror/silver like chip was actually broken and without a schematic it is very difficult to identify. If anyone could possibly help it would be greatly appreciated.
Esta é uma boa pergunta?
Pontuação 0
2 comentários
@blaked89 you can make this "the components close to the battery port connector"and "A mirror/silver like chip " a lot easire by posting a picture with the broken component marked. that way people like @refectio can probalby identify this in no time at all. Use this guide Adicionar imagens a uma pergunta já existente to post some images.
por
Ok thanks, until recently I only read posts but I finally found an issue I could not find myself so I just had put the question out. So first post here. I could upload a picture tomorrow if the pads on the board but the component itself was more or less shattered. The schematic from Minho seems to be the one I’m looking for But I will certainly let everyone know once I find out. I didn’t read his post till after our shops close.
por
Adicionar um comentário
1 resposta
Solução escolhida
In general, a shiny glass component is usually a diode or a MOSFET. Check the screen capture of the iPhone 8 Plus schematic below. There is very little difference between regular and plus models on the basic circuitry.
Esta resposta foi útil?
Pontuação 2
3 comentários:
Thanks, I really appreciate it. I’ll look into it as soon as possible and let you know if I can find it.
por
So i believe it is a TVS but I dont want to post the number/name of the component until I am %100 sure that’s the component that was damaged. Customer is becoming anxious, not sure if I will still have the phone by the time the part comes in. Very fine time limit I am working with lol
Thank you so much for the information and schematic but I do not want to mislead anyone. Will have to update you when it is confirmed. I do apologize.
por
Were you ever able to identify the name of that shiny glass component?
por
Adicionar a sua resposta
Blaked89 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 368
