Ir para o conteúdo principal
Lançado em 22 de setembro de 2017. Modelo A1863, A1905. Disponível com GSM ou CDMA / 64 ou 256 GB / Dourado, Prateado e Cinza Espacial.
873 Perguntas Visualizar todos
iPhone 8 was stuck at 1% now won’t come on.
So I got a phone with a report from one of my techs. The report said after a battery change the phone was stuck at one percent, thinking it was a defective battery she changed it again and now the device will not power on. Screen tests fine, batteries tests fine, charging port tests fine. I trust the tech to be honest and I did find an answer for the “Stuck at 1%” issue. I looked at the component the post directed me to and it was pulled from the board but I also noticed another chip that was broken. A silver like chip just to the left of the RV3C002UN chip by the battery connector port. I can’t find what component this is without a schematic and I cannot find the schematic. Could anyone help me find the name/number of the silver component?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
In general, a shiny glass component is usually a diode or a MOSFET. Check the screen capture of the iPhone 8 Plus schematic below. There is very little difference between regular and plus models on the basic circuitry.
Esta resposta foi útil?
Pontuação 2
3 comentários:
Thanks, I really appreciate it. I’ll look into it as soon as possible and let you know if I can find it.
por
So i believe it is a TVS but I dont want to post the number/name of the component until I am %100 sure that’s the component that was damaged. Customer is becoming anxious, not sure if I will still have the phone by the time the part comes in. Very fine time limit I am working with lol
Thank you so much for the information and schematic but I do not want to mislead anyone. Will have to update you when it is confirmed. I do apologize.
por
Were you ever able to identify the name of that shiny glass component?
por
Adicionar a sua resposta
Blaked89 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 8
Duração total: 570
