Ir para o conteúdo principal
A standard cordless compact DeWalt 18V drill with a high performance motor that delivers 380 watts. Equipped with easy to hold design that allows you to work in difficult spaces.
DeWalt DC970 brush replacment
Can the brushes in the DC970 be replaced or are they part of the motor?
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
2 respostas
Solução escolhida
@countrylogic
Since the motor is the same as for the DeWalt DW959 it most likely uses a brush box. Take a look on here for that. post some more pictiures of your motor etc. when you get to the disassembly, that way we can see what you see. Use this guide Adicionar imagens a uma pergunta já existente for that. DeWalt DC970 Motor Replacement
Imagem de iFixit
Guia
Nível de dificuldade:
Muito fácil
2 - 5 minutes
Imagem de DeWalt DC970 Motor
Guia
Moderado
10 minutes
Esta resposta foi útil?
Pontuação 3
I have the DW959, it has a sealed motor and you cannot replace the brushes. The motor part number is 615321-02SV. Most sites no longer sell it, it goes for about $60.
Pontuação 3
3 comentários:
I was able to obtain the motor for far less than the cost of a full replacement.
por
I just wanted to update my post, I found parts diagrams for the DW959 that show the brushes, however when I took my drill apart you cannot see the brushes and there is no spade connector to disconnect them. That end of the motor is entirely sealed. You may be able to disassemble the motor from the other end and remove the armature but that leaves the brushes 2 inches down in the motor casing. It doesn't look fixable to me.
por
I have a DW970 can't find brushes to purchase for my drill.
por
Adicionar a sua resposta
CountryLogic será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 35
Ao todo: 3,585
