Introdução
If the motor of your drill is not operating properly or not operating at all, this guide will show you how to replace the motor of your drill.
O que você precisa
Compress the buttons on either side of the battery and lift the drill away from battery.
Lift drill mechanism out of the shell.
Desolder the red and black wires from the motor.
Learn more about soldering here.
3 outras pessoas executaram este guia.
3Comentários do guia
Unplug the wires from the trigger switch....don't unsolder.
New motor comes with wires.
Thanks for the heads up on the wires
Is there a fix to replace brushes?
