Dropped in bath iPhone6
Dropped phone in bath!
I bought new battery and placed in rice .
Ordered isoprolol alcohol
Taken apart etc put new battery in but still nothing?
Thank u for help in advance xx
Esta é uma boa pergunta?
Water Itself is not damaging to the board. water in it's purest form is non-conductive. the actual problem is the minerals in the water. (Iron, Calcium, Sodium, Lime) These are conductive and cause damage. unfortunately, they have a much higher boiling temperature than water, so when the water evaporates, (Sped up by the rice) these minerals are left on the motherboard. Rice doesnt actually help the damage, but rather speeds up the drying porcess. If the phone functions WITH the rice treatment, it would have worked without the rice treatment.
as a water damage repair, it still is only 50/50 as to whether or not you can get the device up and running. follow the next steps, andyou may have a functional device.
1) Isopropyl: Take a 99% rubbing alcohal, also known as Isopropyl, and a toothbrush. (New, as it can not be previously contaminated by conductive materials such as saliva, or tap water) soak the board in the isopropyl, and scrub diligently. make sure not to be terribly rough on the board, but still use a heavy handr
Check to see if board works
2) DeOxit (Electronics cleaner): I have used many brands, but DeOxit is the the one i have had the most success for, so i suggest this brand. others may work, and it is only a personal preference. spray the cleaner onto the board, and seal in a tupperware container. let sit for an hour, then re-soak with isopropyl to dilute any lifted dirts, and scrub with the tooth brush. Essentially, after the DeOxit has sat, Repeat step one.
3) Sonic Wash: This is implying you have access to the tool required. usually need a repair shop environment to have one The sonic wash is a tool, usually cosing between 300$-500$. fill it with distilled water and a liquid electronics cleaning solution. this pulses the cleaner underneath components where a brush can not reach. though this is the most successful procedure, it is also the most expensive of the three.
i hope this helps, and if it does, please accept the answer.
4) After all of these procedures, if any funtions aren't working, try replacing the modular component that the function is related to. (Antenna's for signal, Charge port for charging, Camera for camera function, ETC.)
Anything further than this will be a board level failure.
Esta resposta foi útil?
there is probably damaged components, most common 1 is on the back side of the logic board beside the wifi ic but since it was submerged it could be any component
Hi @dreams1
As you know water and electronics and electricity are not a good mix.
The impurities in the water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components.
Rice is good to eat but does nothing to fix the problems caused by corrosion
Don't Put Your Device in Rice. Here's Why...
First do not turn on your phone and then you need to with the phone turned off, remove the battery as soon as possible from the phone to minimize further damage.''
Then you need to dis-assemble the rest of the phone and clean all the affected parts using Isopropyl Alcohol 90%+ (available from most pharmacies) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is <70% IPA, can contain scents and is not as effective. If you do check the label to verify the amount
Here is a link that describes the process.
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to the ifixit iPhone 6 repair guides, which may be of some help.
If this process seems too daunting, take your phone to a reputable, professional phone repair service, experienced in water damage repair and ask for a quote for a repair.
If you decide to do this, do it sooner than later.
Worse thing you can do is put it in rice!... never do that...you want to displace the water not let it dry inside!
and never try to put power to it after the water damage...box it up, and ship to a professional shop that specializes in water damaged devices...
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 95
1 comentário
Thank u very much for your reply. Much appreciated xxx
por Debbie
