Ir para o conteúdo principal
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
Left side of screen not working
My rightside works perfectly but my leftside is unresponsive so i cant get in my iphone bc my 2 pin code numbers are there my screen is cracked notby much i rebooted it multiple times still not working cant do anything until i unlock my phone is there any way to fix unresponsive leftside of screen
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
The first thing to try is to replace the screen with a new or known-good screen. You can follow this guide and order this part.
Esta resposta foi útil?
Pontuação 2
Is it possible that a connection to the screen is not tight enough? Reseate the cable for the display will work for you.You might not need a screen replacement right now. It seems that you are a little bit overworked at the moment.Good luck
Pontuação 0
Adicionar a sua resposta
Darren Grant será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 4
Ao todo: 546
