phone wont charge after being dropped
i dropped my phone and the sound doesn't work at all. Now the phone will not charge at all. Its not even registering the charger being attached
Esta é uma boa pergunta?
Sometimes after a drop, or after repeated drops, the logic board can be damaged, specifically the solder connections underneath some of the IC's. This can affect pretty much any IC and it can cause some unpredictable symptoms.
However, before getting into potential micro-soldering repairs, you need to eliminate the possibility that there is a problem at the modular level. Open up the device and insure that the battery is properly connected, as is the screen assembly. If you have access to another, preferably known-good battery or screen...or even a Lightning port flex, try those too.
If that doesn't solve the problem, then your charge circuit on the logic board is damaged and will require a micro-soldering repair.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 73
Duração total: 13,905
