Ir para o conteúdo principal
Guides for the Wi-Fi version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
Screen wont react to finger
Will the lcd work if i swipe it? No reaction on the ipad. Unsure if its a new lcd ir glass that i need
Esta é uma boa pergunta?
Pontuação 0
1 comentário
What happened to it and what have you done so far?
por
Adicionar um comentário
1 resposta
Solução escolhida
I believe you asked this question yesterday. The LCD is just for displaying the image, avoid touching it as it can be hard to clean (a lenspen works well) and scratches easily. The touch capability is provided by the digitizer (front glass).
If you are having issues with touch, either your replacement digitizer is defective or you damaged the flex/connectors. Closely inspect your work by following this guide.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Nathan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 103
