Ir para o conteúdo principal
iPad Mini 2 Wi-Fi Front Panel Assembly Replacement
O que você precisa
  1. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement, iOpener Heating: passo 1, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement, iOpener Heating: passo 1, imagem 2 %32
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
  2. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 2, imagem 1 %32
    • Heat the iOpener for thirty seconds.
    • Depending on the wattage of your microwave, more or less time may be required. The iOpener is sufficiently heated when it's barely too hot to touch.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100˚C (212˚F).
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
  3. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 3, imagem 1 %32
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
  4. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement, Alternate iOpener heating method: passo 4, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement, Alternate iOpener heating method: passo 4, imagem 2 %32
    • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
    • Fill a pot or pan with enough water to fully submerge an iOpener.
    • Heat the water to a boil. Turn off the heat.
    • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
    • Use tongs to extract the heated iOpener from the hot water.
    • Thoroughly dry the iOpener with a towel.
    • The iOpener will be very hot, so be careful to hold it only by the end tabs.
    • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
  5. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement, LCD Shield Plate: passo 5, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement, LCD Shield Plate: passo 5, imagem 2 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement, LCD Shield Plate: passo 5, imagem 3 %32
    • Lay overlapping strips of clear packing tape over the iPad's display until the whole face is covered.
    • Do your best to follow the rest of the guide as described. However, once the glass is broken, it will likely continue to crack as you work, and you may need to use a metal prying tool to scoop the glass out.
    • Wear safety glasses to protect your eyes, and be careful not to damage the LCD screen.
  6. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 6, imagem 1 %32
    • Handling it by the tab, place the heated iOpener on the side of the iPad to the left of the home button assembly.
    • Let the iOpener sit for about five minutes to soften the adhesive beneath the glass.
  7. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 7, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 7, imagem 2 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 7, imagem 3 %32
    • Carefully place a suction cup halfway up the heated side.
    • Be sure the cup is completely flat on the screen to get a tight seal.
    • While holding the iPad down with one hand, pull up on the suction cup to slightly separate the front panel glass from from the rear case.
    • Be careful to only lift the glass enough to insert an opening pick—any more and you risk cracking the glass.
  8. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 8, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 8, imagem 2 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 8, imagem 3 %32
    • While holding the glass up with the suction cup, slide the point of an opening pick into the gap between the glass and body of the iPad.
    • Don't insert the opening pick any deeper than the black bezel on the side of the display. Inserting the pick too far may damage the LCD.
    • Pull the suction cup's plastic nub to release the vacuum seal and remove the suction cup from the display assembly.
  9. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 9, imagem 1 %32
    • Reheat and reapply the iOpener.
    • Be careful not to overheat the iOpener during the repair procedure. Always wait at least ten minutes before reheating the iOpener.
    • Let it rest for a few minutes to reheat the left edge of the iPad.
  10. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 10, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 10, imagem 2 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 10, imagem 3 %32
    • Place a second opening pick alongside the first and slide the pick down along the edge of the iPad, releasing the adhesive as you go.
    • Throughout the rest of the procedure, if you encounter significant resistance to sliding picks beneath the glass, stop and reheat the section you're working on. Forcing the picks risks cracking the glass.
  11. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 11, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 11, imagem 2 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 11, imagem 3 %32
    • Continue moving the opening pick down the side of the display to release the adhesive.
    • If the opening pick gets stuck in the adhesive, "roll" the pick along the side of the iPad, continuing to release the adhesive.
  12. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 12, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 12, imagem 2 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 12, imagem 3 %32
    • Take the first pick you inserted and slide it up toward the top corner of the iPad.
    • If you can see the tip of the opening pick through the front glass, don't panic—just pull the pick out a little bit. Most likely, everything will be fine, but try to avoid this as it may deposit adhesive on the front of the LCD that is difficult to clean off.
  13. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 13, imagem 1 %32
    • Reheat the iOpener and place it on the top edge of the iPad, over the front-facing camera.
    • Be careful not to overheat the iOpener during the repair procedure. Wait at least ten minutes before reheating the iOpener.
    • If you have a flexible iOpener, you can bend it to heat both the upper left corner and the upper edge at the same time.
  14. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 14, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 14, imagem 2 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 14, imagem 3 %32
    • Slide the opening pick around the top left corner of the iPad to separate the adhesive.
  15. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 15, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 15, imagem 2 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 15, imagem 3 %32
    • Slide the opening pick along the top edge of the iPad, stopping just before you reach the camera.
    • The third image shows where the front-facing camera and housing are in the iPad.
    • Avoid sliding the opening pick over the front-facing camera, as you may smear adhesive onto the lens or damage the camera. The following steps will detail how to best avoid disturbing the front-facing camera.
  16. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 16, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 16, imagem 2 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 16, imagem 3 %32
    • Pull the pick out slightly, and slide the very tip gently along the top of the front-facing camera section of the top edge.
  17. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 17, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 17, imagem 2 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 17, imagem 3 %32
    • Leave the opening pick in the iPad slightly past the front-facing camera.
    • Take a second pick and insert it to the left of the camera, where the first pick just was. Slide it back to the corner to completely cut any remaining adhesive.
    • Leave the second pick in place to prevent the corner adhesive from re-sealing as it cools.
  18. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 18, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 18, imagem 2 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 18, imagem 3 %32
    • Insert the previous pick deeper into the iPad and slide it away from the camera toward the corner.
  19. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 19, imagem 1 %32
    • Leave the three picks in the corners of the iPad to prevent re-adhering of the front panel adhesive.
    • Reheat the iOpener and place it on the remaining long side of the iPad—along the volume and lock buttons.
  20. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 20, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 20, imagem 2 %32
    • Slide the top right opening pick around the corner to fully release the top edge of the glass.
    • Leave this pick in place to keep the adhesive from re-sealing itself, and grab a new pick for the next step.
  21. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 21, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 21, imagem 2 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 21, imagem 3 %32
    • Insert a new opening pick and slide it to the middle of the right edge of the iPad, releasing the adhesive as you go.
  22. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 22, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 22, imagem 2 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 22, imagem 3 %32
    • Continue to slide the pick down the right edge of the iPad, releasing the adhesive.
  23. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 23, imagem 1 %32
    • Leave the opening picks in place and reheat the iOpener.
    • Remember not to overheat the iOpener—no more than once every ten minutes.
    • Set the reheated iOpener on the home button end of the iPad and let it rest for a few minutes to soften the adhesive beneath the glass.
  24. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 24, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 24, imagem 2 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 24, imagem 3 %32
    • Slide the lower left pick to the lower left corner to cut the adhesive on that corner.
    • Leave the pick at the corner. Do not pry any farther, and do not remove the pick from the iPad.
    • There are quite a few things to avoid beneath the lower bezel, so study the third image closely:
    • Antennas
    • Home button cavity
    • Digitizer cable
    • The following steps will direct you where to pry to avoid damage to these components. Only apply heat and pry where directed.
  25. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 25, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 25, imagem 2 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 25, imagem 3 %32
    • Leave the pick from the last step in place to prevent the adhesive from re-sealing.
    • With a new pick, slice gently over the left-hand antenna, stopping before the home button.
    • Only slide the pick from the outer edge toward the center of the iPad. Do not move the pick back toward the outer edge, as moving in this direction may damage the antenna.
    • If you need to slide the pick over the lower section more than once, remove it and re-insert at the outer edge, and slide inwards.
    • Leave the pick in place before moving on.
  26. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 26, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 26, imagem 2 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 26, imagem 3 %32
    • Insert the tip of one last pick next to the previous step's pick, and slide it beneath the home button.
    • Stop about an inch from the right-hand side to avoid cutting the digitizer cable.
    • Insert the pick slightly deeper and work it back toward the home button.
    • Again, be sure to only slide the pick toward the center of the iPad when it is fully inserted; otherwise you may damage the antenna beneath the glass.
  27. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 27, imagem 1 %32
    • Reheat and reapply the iOpener to the top bezel of the iPad.
  28. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 28, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 28, imagem 2 %32
    • Be very careful with this step. Take your time and ensure the adhesive is hot and soft, and that you've been through all of the adhesive with an opening pick. Don't be afraid to stop and reheat.
    • At the top of the iPad opposite the home button, you should have a pick lodged into each corner. Twist the picks to lift the glass slightly, separating the last of the adhesive along all four edges.
    • If you encounter a significant amount of resistance, stop twisting. Leave the picks in place, reheat, and reapply the iOpener to the problem areas, and run a pick through the sticking point one more time.
  29. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 29, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 29, imagem 2 %32
    • Lift slowly and gently to further detach the adhesive along the lower edge.
  30. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 30, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 30, imagem 2 %32
    • Once all of the adhesive has been separated, open the front glass like a page in a book and rest it on your workspace.
    • If reusing the front panel assembly during reassembly, you will need to replace your display adhesive. Use our display adhesive application guide to reapply your display adhesive and reseal your device.
  31. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 31, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 31, imagem 2 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 31, imagem 3 %32
    • The front-facing camera housing may stick to the front panel; peel up the housing and place it back over the camera to protect it.
    • Rock the camera housing up on one edge to free it from the adhesive and remove it from the front panel.
    • Return the front-facing camera housing to its recess in the rear case.
  32. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 32, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 32, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Remove the following Phillips #00 screws securing the LCD:
    • Three 3.3 mm screws
    • One 4.5 mm screw
    • If there is tape covering any LCD screws, peel it up with tweezers.
  33. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 33, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 33, imagem 2 %32
    • Do not attempt to fully remove the LCD. It is still adhered in place and connected to the iPad by several cables at the home button end. Lift only from the front-facing camera end.
    • Insert the flat end of a spudger under the LCD between it and the LCD shield plate and lift gently.
    • Be very careful not to get the spudger under the shield plate. It must be between the LCD and the shield.
    • Even bending the LCD slightly can permanently damage it, so be extremely careful as you lift.
    • You can try these alternate removal methods to reduce your chance of cracking the LCD during the removal process:
    • Run a thin string (like floss or fishing line) under the display, starting from the top then working your way down
    • Use a thin, flexible card or plastic money note to cut through the adhesive starting from the top.
  34. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 34, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 34, imagem 2 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 34, imagem 3 %32
    • The LCD is secured by mild adhesive that should be loosened before you flip the LCD up from its shield plate.
    • Insert the spudger between the LCD and LCD shield plate and slide it to the far edge of the iPad.
  35. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 35, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 35, imagem 2 %32
    • Two wide strips of tape connect the LCD to the speakers.
    • Hold the LCD with one hand, and the rear body of the iPad with the other.
    • Do not attempt to fully remove the LCD from the iPad.
    • Gently pull the LCD away from the speakers to separate the tape, being careful not to pull on the digitizer cable.
  36. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 36, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 36, imagem 2 %32
    • Do not attempt to fully remove the LCD. It is still connected to the iPad by several cables at the home button end. Lift only from the front-facing camera end.
    • Flip the iPad LCD like a page in a book, lifting near the camera and turning it over the home button end of the rear case.
    • Be gentle and keep an eye on the LCD cables as you flip the display over.
    • Lay the LCD on the front panel glass to allow access to the display cables.
  37. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 37, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 37, imagem 2 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 37, imagem 3 %32
    • Slide the tip of a spudger between the LCD and the adhesive tabs to free the display.
    • Push gently between each of the two adhesive tabs; be careful not to damage any of the nearby cables.
  38. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 38, imagem 1 %32
    • Remove the seven 1.8 mm Phillips #00 screws from the LCD shield plate.
  39. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 39, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 39, imagem 2 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 39, imagem 3 %32
    • Use the flat end of a spudger to pry the LCD shield plate up and out of the iPad.
    • Remove the LCD shield plate.
  40. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement, LCD: passo 40, imagem 1 %32
    • Remove the following Phillips #00 screws from the display cable bracket:
    • One 2.7 mm screw
    • Two 1.4 mm screws
  41. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 41, imagem 1 %32
    • Remove the display cable bracket from the iPad.
  42. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 42, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 42, imagem 2 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 42, imagem 3 %32
    • Use the point of a spudger to gently lift the battery connector up off its socket on the logic board.
    • Be very careful to only pry up the battery connector, not the socket itself. If you pry up on the logic board socket, you may break the connector entirely.
    • Make sure to pry up the battery connector before attempting any other repairs inside the device.
  43. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 43, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 43, imagem 2 %32
    • Use flat end of a spudger to lift the LCD connector up off its socket on the logic board.
    • Do not pry against the large IC next to the connector, or you may break it. Gently pry from the side of the connector as shown.
  44. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 44, imagem 1 %32
    • Lift and remove the LCD from the iPad.
  45. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement, Front Panel: passo 45, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement, Front Panel: passo 45, imagem 2 %32
    • Use the flat end of a spudger to lift the digitizer cable connector straight up off of its socket.
    • Be careful as you lift the connector from the socket—the pins in the socket are extremely fragile and can easily break!
  46. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 46, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 46, imagem 2 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 46, imagem 3 %32
    • Slide the spudger under the battery side of the digitizer board to begin separating it from the rear case.
    • Lift the digitizer board up to free the last of the adhesive.
  47. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 47, imagem 1 %32
    • Lift and remove the front panel from the iPad.
  48. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement, Adhere the digitizer cable: passo 48, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement, Adhere the digitizer cable: passo 48, imagem 2 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement, Adhere the digitizer cable: passo 48, imagem 3 %32
    • Your replacement panel may come with this cable pre-adhered.
    • On the replacement front panel, remove the small piece of adhesive backing from the digitizer cable.
    • Fold the digitizer cable back over onto itself and press firmly to secure the adhesive.
  49. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement, Front panel preparation: passo 49, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement, Front panel preparation: passo 49, imagem 2 %32
    • This is a good time to power on your iPad and test all functions before you seal the display in place. Be sure to power your iPad back down completely before you continue.
    • If you're installing a new front panel assembly, it may need the following preparation:
    • Peel the large clear plastic liner off of the inside of the glass.
    • Peel any blue plastic backings covering the adhesive around the perimeter of the front panel assembly.
    • Once removed, the adhesive strips will be exposed. Don't remove these backings until you're ready to install the front panel assembly.
    • Don't remove any copper coverings from the outlined region, such as yellow kapton tape or black electrical tape.
    • Ensure the glass panel is free of fingerprints and grime before installing it on your device.
  50. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement, Transfer the smart cover magnets: passo 50, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement, Transfer the smart cover magnets: passo 50, imagem 2 %32
    • Before you install your new front panel, you'll need to transfer the smart cover magnets on your OLD front panel to your new front panel.
    • Place the edge of a plastic opening tool on each side of the magnet near the top left corner of the front panel assembly.
    • Carefully wedge the edge of the right plastic opening tool underneath the magnet.
    • Steadily hold the right plastic opening tool in place.
    • Wedge the left plastic opening tool underneath the magnet and simultaneously pry and push it towards the right plastic opening tool.
    • This will require some force as the smart cover magnet is held in place with strong adhesive.
  51. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 51, imagem 1 %32
    • If necessary, use a pair of tweezers to partially peel back the piece of tape covering the smart cover magnet near the lower left corner of the front panel assembly.
  52. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 52, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 52, imagem 2 %32
    • Use the previously described procedure to remove the smart cover magnet near the bottom left corner of the front panel assembly.
  53. iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 53, imagem 1 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 53, imagem 2 %32 iPad Mini 2 Wi-Fi Front Panel Assembly Replacement: passo 53, imagem 3 %32
    • In this step you will be transferring the smart cover magnets to the NEW front panel assembly.
    • Use a pair of tweezers to carefully place the upper left smart cover magnet in place.
    • Repeat the procedure with the bottom left smart cover magnet.
    • If necessary, use the edge of a plastic opening tool to flatten the piece of tape adhered to the bottom left smart cover magnet.
Conclusão
285 outras pessoas executaram este guia.
Sam Goldheart
Membro desde: 10/18/12
475.779 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Staff
125 Membros
Autoria de 24.050 guias
51Comentários do guia
Step 16 through step 24
I made a mess:
- I slid the picks all around the glass breaking the glass, the antenna and digit cables.
What do I need to fix it ? I have already ordered by you a front glass and a a logic board
(LCD I have it already). What do I need more ?
Pls. Help
Sergio Ungaro
su40 - Responder
Hey, I have a big problem.
I did all this steps and everything was fine so i put it together. Now I have a ghost-touch if i press the margin at the right edge. I didn't remove the yellow stripe and i thing the cable is not between the frame and the metal.
thx
David - Responder
Had the same issue. Just use Kapton tape and cover the bottom part of the ipad where the Home button is. What’s causing the issue is grounding thus the ghost touch. Search or “Ipad mini ghost touch kapton” on YouTube. Hope this helps.
Yousef Ghalib -
THE LCD SCREEN IS EXTREMELY FRAGILE
you will crack it with the slightest bend. This is crucial as you try to free it from the STRONG adhesive tape at the bottom speakers. This tutorial has no mention of how careful you have to be with the LCD, or how much stronger the adhesion is in this area, but then again, you can always purchase a new LCD from iFixit, riiiiight?
James Billy - Responder
Good info! Thanx
thomas -
Comentar
Visualizações:
Últimas 24 horas: 38
Últimos 7 dias: 1,022
Últimos 30 dias: 6,271
Ao todo: 250,573
