Ir para o conteúdo principal
7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
iPad power button jammed.
I had dropped my iPad mini 2 years ago and the power button got jammed and the screen shattered.
When I had a girl in my class try and get it loose it shattered even more.
It still works, but the power button is jammed and I do NOT want to shatter it even more.
I have a new iPad now, but how can I fix this? I hate using assistive touch to turn it off.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
You'll have to remove the digitizer first and inspect the power button to see why it is jammed. It could be caused by a physical deformation of the housing, which you could redress or it may be caused to something obstructing it internally.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Yep- it's the dented housing for sure. I dropped it and it was dented really bad.
por
Adicionar a sua resposta
Morgan será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 26
Ao todo: 13,972
