Ir para o conteúdo principal
Repair guides and troubleshooting for the Acer Aspire 5750. This is a 2012 Aspire budget laptop aimed at the casual household user or for small business use.
No power from DC.
I was using this laptop and the power died. I realised that it had been running on the battery although the DC mains cable was plugged in. The battery had run out of juice.
There was no DC power LED on indication
I have tested all the obvious things, and have now replaced the DC cable and socket with a new one.
However when I plug it in I still get no DC power LED on indication. Currently the keyboard is removed and I haven't bothered to put it all back together as there doesn't seem any point.
Does anyone know what to try from here ?
Many thanks in advance.
Esta é uma boa pergunta?
Pontuação 0
3 comentários
@oldturkey03 the DC power adapter chucks out 12v. This is still working.
por
usually dc output is 19v is it not
por
yes, 19v. I think I'm using the wrong adapter. so much for "I've tested all the obvious stuff". Thanks for the wake up call, dang.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
@sponge_bob you wrote that you "tested all the obvious things," but did not tell us what the output of your AC adapter is. Should be a 19V 65W adapter
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Sponge Bob será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 3
Últimos 30 dias: 17
Ao todo: 387
