Ir para o conteúdo principal
O Dell Vostro é um modelo de uma linha de notebooks criados pela Dell para uso empresarial. O Vostro 1500 foi lançado em 2007.
My screen died. How do I replace it?
I used this primarily because it had Windows XP. A lot of older games aren’t supported by Windows Vista, Windows 7, Windows 8, etc.
The XP emulator in versions after XP doesn’t’ function well with all games.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
These laptops use a CCFL LCD, which is difficult to find a replacement for today. When you do find them, it's usually a overpriced NOS panel.
If you don't want to give up on this laptop, your best bet is to find a parts laptop with a good LCD that doesn't look heavily worn. If you just buy the screen or screen assembly, it will cost more then a whole new laptop. However, my recommendation is to find a newer model that comes with an XP COA and hopefully has a LED display. XP laptops are usually cheap these days because when XP went EOL, the market was flooded with XP systems. This has essentially made it hard to economically repair XP era laptops that failed without coming close (or exceeding) to the cost of a complete replacement.
The model that I like to replace these machines is the E6410. There's plenty available with an XP license to go around and these can be purchased for relatively cheap. These also use LED screens, so you don't have to worry about LCD replacement cost problems. If you can't find an example with a XP license, you can use the COA from your old laptop and take advantage of downgrade rights, as long as it's an XP Pro license. The catch is you have to get a machine with a 7 Pro license to do this. Home Premium does NOT include downgrade rights.
Esta resposta foi útil?
Pontuação 2
2 comentários:
Thanks for the quick and detailed response.
por
The reason I like the E6410 for cases like yours is that you usually can't find 6420's with a XP license since Dell used downgrade rights on those. By the time the E6420 came out, Windows 7 largely replaced XP/Vista on new systems.
They're not as capable as the 6420, but they have the advantage of being easy to find with XP or 7 Pro (downgrade rights to XP) licenses.
por
Adicionar a sua resposta
Major Faversham será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 13
Ao todo: 389
