Ir para o conteúdo principal
Tela de 7,9 polegadas / Modelo A1454 / Disponível nas cores preta ou branca / Anunciado em 23 de outubro de 2012 / Capacidade de 16, 32 ou 64 GB
Digitizer Plug on Logic Board
Hi Guys,
I have an Apple iPad Mini 1st Gen Model# A1432 here which needed the Digitizer replaced. The plug that the Ribbon Cable clips into on the Logic Board is missing some of the Gold Pins and as a result the Digitizer isn't working. I am not sure what this item is actually called. I was just wanting to know if anyone could help with the of that part and or if it is available to purchase. I will also need to Purchase a new LCD Screen at the same time as when I turned it on it's coming up with 2 apple logo's and lines across the screen. Any help would be greatly appreciated. See picture attached the part I need is circled. Thank you in advance.
Imagem
Regards,
George McMahon.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
You can buy those but you need someone proficient in micro soldering and previous experience of doing those really to attach it correctly.
Esta resposta foi útil?
Pontuação 0
2 comentários:
*cough cough* @refectio *cough cough*
por
Thank you so much for your help. I really appreciate it. I will definitely have to look for someone who is proficient in Micro Soldering as I am not. Thanks again,
Regards,
George McMahon.
por
Pergunta mais útil
@gm78 the connector is a Molex 503304-2010 . It is available at places like this and many others. To repair it you will need to know how to microsolder (and of course have the tools) or get someone like @refectio to repair it for you.
Pontuação 1
3 comentários:
@oldturkey03 where do you find this stuff out? so much random knowledge! =)
por
@captainsnowball it's all random from fixing random things ;)
por
Thank you so much I really appreciate your help. I definitely am not proficient enough in micro soldering so will have to get it done by an expert. I am in Adelaide. South Australia. I will have a hunt around to see if I can find someone here that can do it if not I will look into @refectio to do it for me. I really appreciate your help. Thanks Again.
Regards,
George McMahon.
por
Adicionar a sua resposta
George McMahon será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 18
Ao todo: 691
