Ir para o conteúdo principal
2.2 GHz (Turbo Boost up to 3.4 GHz), 2.5 GHz (Turbo Boost up to 3.7 GHz), or 2.8 GHz (Turbo Boost up to 4.0 GHz) quad-core Intel Core i7 processor with 6 MB shared L3 cache.
773 Perguntas Visualizar todos
Left I/O connector is damaged
Hello Guys,
I have a tough one for ya. I have a Logic-board 820-00138-A with a damaged I/O connector (connector A). Does anyone know If I can replace the connector with a connector B (from the I/O cable) or have a source for this part, other than buying a whole Logic-board? Both A and B connectors are the same size and each have 20 pins. I also tested the female side of the I/O cable and it does fit both A and B connectors.
tl;dr: Can I De-solder this connector from an I/O cable and reuse it, or do I have to buy another Logic board?
The Damage
Update: This connector is the worst. I managed to misplace a couple of these arch pins.
Esta é uma boa pergunta?
Pontuação 0
6 comentários
Why Don't you post a pic so people can see how bad it is.
por
Its nice and toasty.
por
I've never micro soldered so I bet @tcrs_circuit could help you out.
por
@anthonyj - You still need to figure out what caused the short and if more damage is present on the logic board.
por
Anyone have a spare .brd file? ;) I'll buy it shortly.
por
Exibir mais 1 comentário
Adicionar um comentário
1 resposta
Solução escolhida
The connectors look pretty similar based on the photos. You would need to use a digital caliper to verify that they are indeed identical. Donor boards aren't usually that expensive and can offer lot's of spare parts as well so they are a great way to get parts that are difficult/impossible to source.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Anthony será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 175
