Power On No display
Its Power on but gives display sometimes and sometimes not give display
Esta é uma boa pergunta?
Hi,
Connect an external monitor and check if it shows a display OK.
Also when the laptop screen shows no display, use a torch and shine it at an angle close to the screen and check if you can detect a display at all. It will be very faint so perhaps it will be easier if you try this in a darkened room
Esta resposta foi útil?
try to open it up and disconnect the screen then clean the screen connectors with alcohol assembleitup and retry
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 29
Ao todo: 1,047
1 comentário
maybe a loose cable
por daniel
