Ir para o conteúdo principal
The Kindle 4 has 4 models released September 28, 2011.
72 Perguntas Visualizar todos
Is it possible to get the charging port repaired?
My kindle can no longer be charged as the pins on the device are damaged. Is it possible to get this repaired?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
of course it is, just depends what repair shop you go to
Esta resposta foi útil?
Pontuação 1
jackiewarner yes it is but will require some work. You will have to disassemble your Kindle and could be using this video as a guide. Then you have to un-solder the old connector and replace it with a new one. The new ports can sometimes be gotten from places like ebay etc. but can still be unreasonably expensive. Not a terribly complicate job, more a PITA.
Pontuação 0
Adicionar a sua resposta
jackiewarner será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 41
