Ir para o conteúdo principal
7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
220 Perguntas Visualizar todos
Ripped tape from LCD to Speakers, is this a problem?
When removing the LCD, I tore the tape while trying to remove it.
Its the pieces from the LCD along the bottom onto the speakers.
Are those essential for electrical contact?
Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Do you mean the tape at Step 45 of this guide?
It's not ideal but I don't think it makes a lot of difference either way. Sometimes the tape just won't adhere properly (like during a second repair) and it causes no issues. So I doubt the tape being torn would cause any issues.
Esta resposta foi útil?
Pontuação 2
2 comentários:
That's it, thank you.
I'm just concerned because now the home button isn't responding.
Maybe it's the new digitizer assembly?
por
Probably, however there are a lot of gotcha's when it comes to properly assembling a mini digitizer. Make sure the bottom of the digi looks like this picture (iPad Mini Wi-Fi Front Panel Assembly Replacement). If you see exposed contacts like on Step 62, you need to cover those with an anti-static tape (Kapton).
por
Adicionar a sua resposta
David será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 84
