Ir para o conteúdo principal
Notebook Acer Aspire V3-771G. Este modelo faz parte da linha de telas de 17,3" oferecida pela Acer.
I have problem in the screen
I have laptop Acer V3-771 and i have problem in monitor :
The problem is : the output for the screen is white color.
I wont solve for this problem .
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Thank you very much for your advice
por
Adicionar um comentário
1 resposta
Pergunta mais útil
@qutaiba72white screen means that the backlight is on but your display does not receive any data. Check with an external monitor and see if that displays properly. If it does, you know that you GPU is circuitry is working. Check the cable to your LCD and you may have to replace the LCD. If it does not then your issue is with the GPU so you will have to check on the motherboard. For that you would need the schematic
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Qutaiba Saoor será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Ao todo: 493
