Ir para o conteúdo principal
Released in November of 2012, this laptop has a 15.6 inch LCD screen, an AMD Dual-Core Processor, and 2 GB of expandable RAM.
9 Perguntas Visualizar todos
Why is my laptop not charging yet the power pack is functional.
My laptop is not charging even the charging light is not turning on without a charged battery or @ 0% (even as a desktop) ,however even if the battery is charged and the powerpack is plugged in ,the battery percentage still falls ,though the charging light is on and the battery icon on task bar shows that the powerpack is plugged in.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
my batt are no chargin
my batteries are not charging they are plugged in suggestions please?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
gutsa marvelous tatenda "though the charging light is on and the battery icon on task bar shows that the powerpack is plugged in" means that your computer recognizes that your AC power adapter is plugged in. Start off by replacing the battery. That will give you at least a known-well starting point should further troubleshooting become necessary. Here is the guide for that Toshiba Satellite C855D-S5303 Battery Replacement
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
gutsa marvelous tatenda será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 3
Duração total: 747
