Ir para o conteúdo principal
Toshiba Satellite C855D-S5303 Battery Replacement
  1. Toshiba Satellite C855D-S5303 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Lay your laptop upside down on a flat surface.
    • Power off your laptop and unplug the charger.
    • Make sure you allow the laptop time to cool so that you aren't removing a hot battery.
  2. Toshiba Satellite C855D-S5303 Battery Replacement: passo 2, imagem 1 %32 Toshiba Satellite C855D-S5303 Battery Replacement: passo 2, imagem 2 %32
    • Locate the right eject switch, labeled "1".
    • Slide the switch all the way to the right and it should stay in place.
  3. Toshiba Satellite C855D-S5303 Battery Replacement: passo 3, imagem 1 %32
    • The second eject switch is on the left and it is numbered "2".
    • Slide the switch to the left and remain pushing on it, because unlike switch "1" it will not stay in place on it's own.
  4. Toshiba Satellite C855D-S5303 Battery Replacement: passo 4, imagem 1 %32 Toshiba Satellite C855D-S5303 Battery Replacement: passo 4, imagem 2 %32
    • With hand still pushing the left switch, grab onto notch at the center of the two switches.
    • Pull up and towards you. The battery will begin to lift out of the device.
  5. Toshiba Satellite C855D-S5303 Battery Replacement: passo 5, imagem 1 %32
    • The battery can now be pulled out entirely. You are ready to replace it.
Conclusão
Courtney Burns
Membro desde: 10/20/16
863 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 2-5, Isaacson Fall 2016 Membro de UMass Dartmouth, Team 2-5, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G5
3 Membros
Autoria de 10 guias
Um comentário
It appears likely that these batteries are NICAD type. And NiCad batteries CAN be reprogrammed to accept charge.
Is that possible with these Toshiba units?
Rick Walker - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 17
Últimos 30 dias: 18
Ao todo: 1,067
