Ir para o conteúdo principal
The BlackBerry Classic (also known as the BlackBerry Q20) was released in 2014. Model numbers: SQC100-2, SQC100-3, SQC100-5.
24 Perguntas Visualizar todos
The phone overheat pretty much
Hi Sir,
Well, I also bought blackberry classic q20 last month but I have started experience the same problems of the phone overheat pretty much and yet I don't even use the phone a lot and I just use only caling and check the Internet in 30minutes but the phone overheat seriously. I real need help over that problems. Thanks Chris
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
@ochan885 you do want to start with a new battery. It is possible that the battery is at the end of its lifecycle and starting to fail. Replace it and let us know if that made a difference. the first few steps of this guide show you how to remove the battery.
Esta resposta foi útil?
Pontuação 2
These snapdragon S4 chips like to get really hot under load. Heat is pretty normal. The phone has several thermal sensors and will power off if it gets too hot.
Pontuação 1
Adicionar a sua resposta
ochan christopher será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 378
