Ir para o conteúdo principal
Fones de ouvido estéreo da série ZX MDR-ZX100 fabricados pela Sony.
Both the speakers are not working
Both the speakers are not working and I have checked the whole wire and it is working for another speaker and I have connected the speakers with another wire it not working...hence the problem is with my speakers. Please help
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
nitheesh k unlikely that both speakers have failed. Check the 3.5mm plug. Check it and replace it as necessary, follow this guide Reparo do plugue de 3,5 mm do Skullcandy SCS-SCBP SKULLCRUSHERS to do so. Different model headphone but identical procedure. you can also check the wiring to the drivers (speakers) by using this guide Reparo do Sony MDR-ZX100 and measure continuity with a multimeter from the connector to the drivers.
Imagem de Skullcandy SCS-SCBP SKULLCRUSHERS
Guia
Nível de dificuldade:
Moderado
45 minutes - 1 hour
Imagem de Sony MDR-ZX100
Guia
Moderado
15 - 30 minutes
Esta resposta foi útil?
Pontuação 1
The problem is most likely with your speakers, but it is unusual that both speakers fail together. Are these speakers connected to a computer? Such have a power supply inside one of them and if that fails the speakers do not work. As most of these have an external wall-plug supply, check this (measure voltage at the output plug). If there is no voltage just replace the "wall-plug" supply with one of the same voltage and Ampere rating.
If your problem is with regular speakers that you connect to am amplifier I have no idea what may be wrong with both of them.
Pontuação 0
Adicionar a sua resposta
nitheesh k será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Ao todo: 368
