Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3530 Perguntas Visualizar todos
Water Damaged - How to Fix?
I've got an iPhone 5s that is water damaged and will not turn on. What is the best way to go about trying to repair it without replacing the logic?
Will acetone work to clean off the board and connectors? Should I just fully submerge it? Is there anything else I should try to clean other than the logic?
All help is much appreciated. Thanks!
Update (05/17/2017)
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Do not put your phone in rice! The rice myth kills too many phones...
The water is inside the phone, on the logic board and under the shields, even under the IC's. The rice is nowhere near where the water is. So while it ‘’may’’ soak up some water vapour, the real problem is the corrosion that is taking place as the water evaporates. Powering on the phone accelerates the process. The longer you let a phone sit in rice, the more time you are giving corrosion to damage your logic board. The saltier or harder the water is, the more damage will occur.
  • Open your phone and remove the logic board (follow this guide)
  • Inspect the logic board, especially around the connectors and look for corrosion.
  • Inspect both sides of the board. Unfortunately, 80% of the board is covered in shields. That's usually where the damage is occurring.
  • Put your board in a container with >90% isopropyl alcohol and let it sit for a while.
  • Use a soft brush, like a toothbrush and lightly brush away any corrosion you see.
  • Rinse in alcohol and repeat.
  • Let it air dry for a day.
  • Re-assemble and hope for the best.
Use a tool like 3uTools to flash the firmware as it may be corrupted.
You should also consider getting a new battery
A professional repair shop that does water damage repair may be able to recover your phone or the data because they have access to pro-level ultrasonic baths and specialized cleaners as well as the skills to troubleshoot your board. Many shops have a no fix/no fee policy so you don't have to spend money to find out if the phone is fixable or not.
Esta resposta foi útil?
Pontuação 4
12 comentários:
Removed the logic, it is a little sticky but the connections all look okay. Water damage indicator on screen was pink and battery is slightly bubbled. Guess I'll order a battery, screen, and clean this logic and inside of phone off with ISO alcohol and then hope for the best. Any other suggestions?
por
Start with what I suggested. If it doesn't work, then the shields will have to come off for a proper decontamination.
por
Thank you! Leaving the question open until I get parts in but I'd say that fixed it!
por
Got it all put together - new screen and battery. Unfortunately, nothing. How do I take the shields off? Would pictures of the board help? The board has no visible corrosion.
por
If you can take good, focussed, close-up pictures, than yes, please add them to your original question. As far as removing the shields, the easiest way is to use a hot air station and blow evenly around the shield. You can use tweezers to pull up on the shield but don't force it, it should just lift when its ready.
por
Exibir mais 7 comentários
Adicionar a sua resposta
devansmain será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 147
