No start on electric starter
My scooter starts fine with kick starter but has no spark when I try to use electric starter.
It has new battery and ignition coil and plug.
Turns over fine just won't catch
Esta é uma boa pergunta?
I have a Yamaha tweet 50cc kick start works but not electric starter l have new battery new starter botton n spark plug what else can it be
Esta resposta foi útil?
Check for spark at your spark plug. Replace after testing the CDI. (Capacitor Discharge Ignition) Replace coil wire. Check the starter relay with a voltmeter. Next check the voltage regulator. The last worst-case test is your Stator. Can also be your timing is off. I just performed all these steps except replacing the Stator but that tested alright with the meter. I still think 1 of the New ignition wires is grounding out my kill switch, ran fine until I replaced the New Ignition Module Assembly because I lost my keys. I will post when I resolve Which Wire is the Problem.! P.S. Electric start working fine now after changing some wires around on the ignition( New 1 has 5 wires and only 4 connect. The kickstart will not start it though, barely turns the engine.
It's an electric kick scooter guys sorry
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 48
Ao todo: 2,902
@lawless sounds like a wiring issue. What make and model is your scooter?
por oldturkey03
My scooter is a hover one eagle and so when I got it and it didn't turn on I started troubleshooting when I opened up the display unit in the neck I found that there was a set of wires not connected it has a black connector and there's five wires to it there is nowhere that I have found in the neck or the display unit that these wires hooked to
por 4newbeginins75
