Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3530 Perguntas Visualizar todos
Is my phone circuit still good
My phone stopped working and I whent to a repair shop and they said the phone is bad and they took the battery. When I whent home I plugged it in with out the battery and it turned on and then turrned off is it possible the phone can still work, or is the circuit still good.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Why did the shop take your battery? Did they explain why?
Your phone will not boot up completely without a battery, even if it is plugged in to a charger. You would need to try a new battery to see if your phone works properly or not.
Esta resposta foi útil?
Pontuação 1
2 comentários:
The phone did not turn on even if it was plugged in. So they replaced the battery and it did not work so they took their battery back and they tossed away my battery because the guy broke my battery.
por
How did they break your battery? I know I have had some come out not to pretty but never bad enough where they are broken.
If I am understanding correctly when you plug the phone in to power it turns on to the apple logo but will not fully turn on? I would most certainly try a confirmed good battery with a charge.
por
Adicionar a sua resposta
Mohammadali Khalifa será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 64
