Ir para o conteúdo principal
Non OEM Screen issue
hi guys, i just purchased screen on ebay from the seller " GadgetFix " and i installed it, it is working great, but i just noticed that when i take selfie with Flashlight, screen flashs, photo is taken, then camera is watching me in live, it works, but ! everything freezes, touchscreen, buttons, vibration, lock button, home button, can't do anything before i force restart the phone... i tried now another screen wich i took from another phone, it is new, it is oem, and it worked great, even when i try to take selfie with flash, it works great, so technician said that this problem was caused by non OEM screen... seller is not accepting return, i haven't got more money to buy new one, i need screen, how can i fix this one? 3D touch works great too, it looks like original one if there wouldn't be that one defect on selfie flash... help me guys please
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Did the replacement screen you ordered come with the front camera and sensors? If so, then harvest the front camera and sensor from your original, broken screen and install it in the new screen.That should solve your problem. Use this guide.
If the replacement screen did not have the camera and you already transferred yours and it doesn't work, then use the same guide to make sure you installed everything correctly.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Daniel Gate será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 159
