Ir para o conteúdo principal
The Toshiba Satellite A665-S6094 is a laptop computer.
How do I insert an SD?
What do I need to insert a scan disk SDHC?
Esta é uma boa pergunta?
Pontuação 2
2 comentários
Only get first page of guide. There is a memory card reader on the left side of the satellite 665 laptop with a "blank" or tray in it which removes easily. This is a scan disk sdhc card which I wish to update a gps device. It doesn't fit properly in the blank.
por
Hi,
1.Turn the card so that the contacts (metal areas) are face down and towards the laptop as you insert it.
2 Push the card into the slot until it locks in place with a click
To remove the card first make sure that you 'remove the device' in Windows before pushing IN the card to release it. It will spring back out of the slot enough, so that you can grab hold of it to fully extract it.
por
Adicionar um comentário
2 respostas
Pergunta mais útil
If theres a SD port it would be on the sides, or the front. It could also be plugged with a blank to prevent dust from entering, if so give it a press and it will click
Esta resposta foi útil?
Pontuação 8
2 comentários:
Thank you. It is in the middle front all by itself. I never noticed it before.
por
The blank is meant to only safe guard the slot, insert the card into the same slot without the blank and press in until it clicks. press in again to release but make sure you "safely remove hardware" so you wont corrupt data.
por
@rjlayne1 download the user guide from here. Page 146 of that guide will show you how to use the memory card reader. To use a micro or mini SD™ Card, an SD™ adapter is required.
Pontuação 4
Adicionar a sua resposta
Rebecca Layne será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 23
Ao todo: 2,467
