Ir para o conteúdo principal
Model A1059 or A1099 / 20, 40, or 60 GB hard drive / touch sensitive click wheel
Swollen battery affecting middle button.
Old first generation iPod "brick" required new battery 4 years ago that was swollen and preventing middle button from functioning. Apple retailer did repairs but now Apple is prohibiting their stores from working on discontinued products or even ordering parts. This is a relic that still works great. Appreciate any suggestions or options vs. purchasing a replacement.
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Joe, lets identify your iPod properly first. The first generation iPod did not exist as a 60Gb model. What is the AXXXX number of your iPod? What repairs were done and what are the issues now?
por
Model No. A1099, EMC No. 2022. Circa 2004. Sorry, may have been ill advised regarding what generation it is.
4 years ago the center button became stiff and unresponsive. Turned out the battery was going bad and characteristically swells in the center right under the center button. The ring and other controls were not affected. Local Apple reseller tech easily repaired it. Same problem has now reoccurred, and the same Apple tech that fixed it last time feels it's the same issue. But, Apple now prohibits him from working the device.
por
Adicionar um comentário
2 respostas
Solução escolhida
Joe, first thing you want to do is to open it up. Use this guide for that. Discard the battery properly and of course replace with a new one. At this time I would consider replacing the click wheel. A replacement may be a bit hard to find, but they are still around. Follow this guide for that and as a last step remove the clickwheel. It is simply glued in to the front panel
Imagem de iPod 4th Generation or Photo Battery
Guia
iPod 4th Generation or Photo Battery Replacement
Nível de dificuldade:
Moderado
15 minutes - 1 hour
Imagem de iPod 4th Generation or Photo Logic Board
Guia
iPod 4th Generation or Photo Logic Board Replacement
Moderado
20 - 45 minutes
Esta resposta foi útil?
Pontuação 1
I'm guessing you have an iPod Video 60GB. You can get the part from iFixIt:
iPod Video 60/80 GB Battery
Here's the repair guide (make sure your iPod is the same as this before ordering the battery):
iPod 5th Generation (Video) Battery Replacement
Imagem de Replace a battery compatible with an iPod Video 60 or 80 GB. Model #616-0232. 850 mAh.
Produto
$13.99
Pontuação 0
1 comentário:
por
Adicionar a sua resposta
Joe será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Ao todo: 332
