Ir para o conteúdo principal
Dell SFF computer introduced in 2002. Buyer had a choice between a Celeron or Pentium 4 processor. The expansion port selection is as follows 1 AGP (optional) 1 motherboard PCI, and 2 more on a PCI riser card.
My computer is stuck on standby. what do I do.
I've had my DELL 4500S home COMPUTER IN STORAGE for over a year. Tried to hook it up and it wont turn on. The light is orange. I think its stuck on standby. I tried restarting it but I get the same thing. And there doesn't seem to be connection between the computer and monitor. It is in standby also
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Pergunta mais útil
Bad power supply due to bad capacitors. 12V CPU power failure most likely. Check the motherboard as well - both parts are notoriously bad for it.
Unless you get the power supply cheap, it’s not worth trying to repair it. If you’re lucky it’s the RAM but experience tells me bad caps.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
broadzillalmc será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 412
