Ir para o conteúdo principal
Monitor de 24"; câmera iSight, microfone e alto-falantes integrados; resolução de 1920x1200. Lançado em outubro de 2008, identificado pelo número de modelo A1267.
Common Logic board burn spot?
Hello
My cinema display started smelling weird and then shut down. I opened it and found the problem to be a burned spot on the logic board. No problem I'll just replace the logic board and then I can use it again.
So I was browsing for a new board when I saw a dutch thread with someones logic board also burned. But the weird thing is that the burn is at the exact same place.
Imagem
Does anyone have had a problem with a burned board?
Esta é uma boa pergunta?
Pontuação 4
2 comentários:
Lukas Guy, it might help if you add some images to your question. That will allow everybody to see where the board gets damaged
por
Hi Lukas Guy, I have a Apple Cinema with probably the same issue. How did you replace this part? Where can i buy this part?
Gr. Vincent (from Holland as well)
por
Adicionar um comentário
1 resposta
Lukas Guy, that looks like the LED driver. It is most likely a "common" failure if you have a short within the backlight circuitry. Any short there would take out that driver. I would suspect the primary offender would be the LCD connector.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Lukas Guy será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 17
Ao todo: 2,802
