Ir para o conteúdo principal
O C720 é um Chromebook de baixo custo da Acer baseado no ChromeOS. Lançado em 2014, é o sucessor do C710.
How do I fix a dead screen?
With no other indications the screen has stopped working completely, and it just showing black. Is it possible to replace the screen myself? If so, what part do I need to order and how do I open this guy to get in there and make that replacement?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Pergunta mais útil
Kode, first make sure that the issues is your LCD. Connect an external monitor and see if it displays correctly. If it is your LCD that needs to be replaced, follow this video
Esta resposta foi útil?
Pontuação 3
6 comentários:
screen was hit by toy now shows a rainbow what do i do i just ordered a new screen///
por Compartilhar
Hi quireapril,
Click on the link 'this video' above in OT03's answer. It is a video that shows how to replace the screen in an Acer C720 Chromebook.
por Compartilhar
Hey, I followed this because I had a dead screen too. It's still dark, what do I do?
por Compartilhar
@Sean Davis you are not telling us what you did. I assume your computer is a Chromebook C720
por Compartilhar
Hello. How do I fix a computer monitor that won't turn on? It was perfectly fine yesterday but then completely won't work the next day. Whenever I plug in the monitor, its power button usually lights up red but now it doesn't. Does this mean it has a power issue?
por Compartilhar
Exibir mais 1 comentário
Adicionar a sua resposta
Kode será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 25
Ao todo: 2,307
