Ir para o conteúdo principal
O HTC One (codinome M7) é o smartphone topo de linha de 2013 da HTC. Ele possui uma estrutura monobloco de alumínio com design fluido, dois alto-falantes frontais grandes e uma tela de 4,7 polegadas 1080p.
How to fix the cracked screen?
My screen isn't shattered per say but it has a crack at the point of impact. Then the cracks become less visiable as it goes away then leads to the end of the screen. I know that it is nearly impossible to get inside of the HTC One much less fix the screen. Any help would be great.
Esta é uma boa pergunta?
Pontuação 4
1 comentário
Thanks i'll let you know how it goes
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Connor Dempsey, use this teardown to give you an idea of what is involved. The display assembly isright here. Hope this helps, good luck.
Esta resposta foi útil?
Pontuação 1
4 comentários:
not quite sure why this was voted down. Just because somebody does not like it, does not make it a wrong.
por
alcs99 gave you the down vote. I'll up vote to cancel.
por
Thank you Sir. Not quite sure why alcs99 would do so. I would appreciate if people would at least say why they downvote an answer.
por
No disrespect guys! In my comment I hope I explained it well enough why I gave this comment a down vote. The iFixit staff's method of pulling it apart is not the way to do it and in my guide I show the correct way to do it. Much love and keep on fixing!
por
Do not follow ifixit's teardown, the method they used to open the phone to get at the internals is not the best way to do it. I posted a guide on repairing the screen with links to videos on how to properly open the phone and remove the back cover.
Substituição do conjunto do display do HTC One
Pontuação 0
Adicionar a sua resposta
Connor Dempsey será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 16
Ao todo: 9,938
