Ir para o conteúdo principal
Ajuda
CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown
Editando passo 3 —
Tipo de Passo:
Arraste para reorganizar
Turn the fan around so that the front is facing upwards. Remove the front grill by carefully popping out the edges from the plastic tabs around the enclosure.
Remove the fan blade by carefully forcing it off the motor shaft. It may help to use the wrench as a lever and slowly push it out.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
