Ir para o conteúdo principal
O que você precisa
Este teardown (desmontagem analítica) não é um guia de reparo. Para reparar seu/sua Fan, use o nosso manual de serviço.
  1. CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Safety and Supplies: passo 1, imagem 1 %32 CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Safety and Supplies: passo 1, imagem 2 %32
    • Gather the required tools: a small Phillips head screwdriver and a smart wrench.
    • Make sure the device is unplugged and fan blade is not spinning before starting.
  2. CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Opening the Shell: passo 2, imagem 1 %32 CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Opening the Shell: passo 2, imagem 2 %32 CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Opening the Shell: passo 2, imagem 3 %32
    • Unscrew the clip-on stand that connects the fan. This can be done by hand.
    • Turn the fan so that the back is facing up and remove the screw on the upper part of the housing.
    • Remove the back casing to reveal the switch's screws on the inner part of the casing. Remove those as well.
    • The switch's settings:
    • Off (center)
    • Speed 1 (left)
    • Speed 2 (right)
  3. CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Removing the Fan Blade: passo 3, imagem 1 %32 CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Removing the Fan Blade: passo 3, imagem 2 %32
    • Turn the fan around so that the front is facing upwards. Remove the front grill by carefully popping out the edges from the plastic tabs around the enclosure.
    • Remove the fan blade by carefully forcing it off the motor shaft. It may help to use the wrench as a lever and slowly push it out.
  4. CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Looking at the Motor: passo 4, imagem 1 %32 CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown, Looking at the Motor: passo 4, imagem 2 %32
    • Now that the blade is removed. The motor can now be removed from the other half of the housing.
    • Remove the two screws indicated in order to take the module out of the plastic.
    • The motor is connected to the blue transformer. The yellow and white wires indicate the two power outputs for the speed of the motor's rotation.
  5. CH-6CF 2-Speed Clip-On 6-Inch Fan Teardown: passo 5, imagem 1 %32
    • That's it! There isn't too much when taking this device apart.
    • Note: You can further expand on the teardown by taking apart the transformer to DC motor set-up, but it's such a simple circuit that it isn't necessary to look at it.
Justin
Membro desde: 12/08/14
111 Reputação
Autoria de 1 guia
4 comentários
Hi How do you find the replacement switch?
sadeyealso - Responder
the switch melted….
Hi, I was wondering where I could find a clip and base for a 6 inch fan. The fan itself works just fan. Preferably it should be an online store.
Thanks for reading.
Nova Apex - Responder
Is it possible to purchase a replacement blade?
Wayne - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 24
Duração total: 4,357
