Ir para o conteúdo principal
Ajuda
Right Joy-Con Teardown
Editando passo 5 —
Tipo de Passo:
Arraste para reorganizar
Using an opening pick or the flat side of the spudger, pry up the battery from beneath it.
There is some light adhesive holding down the battery which may require some force to overcome
Take care not to puncture the battery. Try prying up the battery from one side and using the angle to pull it off the adhesive. If this does not work, use some isopropyl alcohol to soften the adhesive
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
