Ir para o conteúdo principal
Ajuda
Right Joy-Con Teardown
Editando passo 2 —
Tipo de Passo:
Arraste para reorganizar
To separate the shell halves there are two options:
1. Use an opening pick and insert it between the IR sensor and other half carefully prying them apart
2. push up on the rail towards the shell halve not attached to the IR sensor
With the shell halves separated, carefully put the side with the rail next to the other half
There are two ribbon cables connecting the half with the rail to the other side
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
