Ir para o conteúdo principal
Ajuda
Nintendo GameCube Teardown
Editando passo 5 —
Tipo de Passo:
Arraste para reorganizar
Now remove the heatsink. Unscrew the six screws holding it.
Now use anything flat and durable to carefully lift up the heatsink by putting it under the aluminum and using it gently as a lever.
Be careful using a tool to lift up the heatsink. If removing the heat sink is difficult, use a hairdryer or heat gun to warm the thermal pads and gently twist the heatsink off by hand.
Suas contribuições são licenciadas pela licença de código aberto Creative Commons.
