Ir para o conteúdo principal
« Voltar para Todas as Histórias
iPhone 4 5-Point Pentalobe Screwdriver modification needed
dbuckel -
iPhone 4 Verizon
Imagem da história
iPhone 4 Verizon Rear Panel Replacement
5 minutos
Easy
Meu Problema
Purchased the screwdriver to repair a broken back cover on an iPhone 4.
Minha Solução
Fixing the iPhone was very easy and quick. Unfortunately, the screwdriver had to be modified prior to use. The tip of the screwdriver was too long and came to too fine of a point to grip the screw.
Meu Conselho
Very, and I mean VERY, gently grind or file off a small amount of the excess tip. I'd suggest grinding a little and testing the fit and then grinding some more if needed. Be sure to keep the tip square to the grinder.
Imagem de P2 Pentalobe Screwdriver iPhone
$5.99
Imagem de iPhone 4 (CDMA/Verizon) Blank Rear Glass Panel
$9.99
0 comentários
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Ao todo: 204
